Upgrading 998 Engine
Posted 15 February 2014 - 09:54 PM
Posted 15 February 2014 - 09:57 PM
Cheap and cheerful would be a stage one kit but as yours is in bits then i would look at getting some head work done and then fit a decent camshaft.
It might pay you to pm either Cooperman or ACDodd and pick their minds, a wealth of experience there.
Posted 15 February 2014 - 10:46 PM
If you don't need it urgently I'd be thinking about doing as much of the work myself. A lot of performance can be gained by building to fine tolerances, AC Dodd has lots of info on this though I can't remember where I read it. Also have a read of Visard's book, gives you a lot of info on how to modify things to increase performance. Things like how to modify a cylinder head, inlet and exhaust and the carb. I'd buy myself a dremel and do the modifications myself.
Posted 16 February 2014 - 12:46 AM
Posted 16 February 2014 - 08:10 AM
A dremel is next to useless on most engine parts, there's certainly no way you'd be able to port a cylinder head with one, not unless you live to be 100 years old.
Here's a link to the David Vizard book. http://www.ebay.co.u...9ec#ht_82wt_958
It's quite old now but there's some solid info contained in it & it's certainly worth owning.
Phil.
Posted 16 February 2014 - 10:59 AM
Phil.
Really? What does everyone use for cylinder head porting and carb modifications then?
Posted 16 February 2014 - 11:13 AM
Posted 16 February 2014 - 11:42 AM
A cheap die grinder & some carbide burrs will do the job far far quicker & easier than a dremel ever will.
Phil.
Posted 16 February 2014 - 12:36 PM
Posted 16 February 2014 - 08:49 PM
Phil.Really? What does everyone use for cylinder head porting and carb modifications then?
Ye olde dentist's drill here. 8000rpm! ![]()
Posted 16 February 2014 - 08:56 PM
If you are grinding the ports out then wear a mask or you will suffer later in life
Posted 17 February 2014 - 05:51 PM
Ear defenders too, or, like me, you'll end up with tinnitus and that truly is not pleasant!
