So this morning ish I was working on the suspension after giving up yesterday, I got one side out yesterday. Today I was trying to get the passenger front side trumpet out. Basically what happen was I put the cone compressing tool into the hole, and tightened it down pretty far. The trumpet was loose and moving but didn't come out so I kept tightening and checking then I heard a loud bang and found the tool had burst up and let go of the cone and not I cant seam to get the tool to thread onto the cone. So what do i do people i need to get the trumpets changed please help its my second day in a row failing to get anything done on the car.
The car is a mk1 1964 Austin mini as far as I am aware the finer threaded tool worked on the driver side, and the other bar wouldn't thread onto either cone so I used the fine thread on the passenger side too.
Finally where on Earth do I put the axel stands on the rear subframe and where do I jack on the read subframe.
PLEASE HELP GUYS!!!!!!!
If you need anything else just ask and I'll let you know.
