Indicators And Hazards Not Working But Interior Light Does
Posted 16 February 2014 - 09:53 PM
I desperately need some help....both indicators and hazards don't work, but interior light does....I've looked at the wiring diagrams in Haynes but can't identify my wiring loom...checked fuses still can't get them working... Checked for power at hazard switch .....nothing.
Any ideas? This is the only thing left for me to do before I mot the car....I am not very good with electrics
Cheers....matt
Posted 16 February 2014 - 09:56 PM
try getting a new hazard switch mine stopped working new hazard switch and they work now :)
Posted 16 February 2014 - 09:59 PM
Posted 16 February 2014 - 10:00 PM
Thanks for the quick reply...I will get a switch, but I've tested for power at the switch and found nothing?? This is the bit that I don't get as obviously a new switch wouldn't solve this problem....
have you tried the inline fuse (if yours is messed up like mine) i have an inline fuse under the front scuttle have a look.
here is the circuit
Posted 16 February 2014 - 10:01 PM
Posted 16 February 2014 - 10:05 PM
Posted 16 February 2014 - 10:11 PM
Cheers for the circuit image.....i have had problems locating the flasher units...I found one near the steering column that is a black flasher unit.....not sure if it s indicator or flasher...don't know where the other one is....any ideas??
the one near steering wheel is indicators the one on the front scuttle is the flasher
Posted 16 February 2014 - 10:12 PM
Posted 16 February 2014 - 10:17 PM
Posted 16 February 2014 - 10:24 PM
Ok thanks for the info...are both flashers black then???? I've looked before and only found a load of yellow relays... Under the steering column I have one black flasher and a pink relay or something....
the one near the steering wheel for indicaters is silver the pink one is the dim dip relay for the lights dont touch it if it works. and the one in the engine bay is silver as well.
Posted 16 February 2014 - 10:25 PM
Think I had the same trouble when the earth had fallen off my Hazard switch.
Posted 16 February 2014 - 10:26 PM
Posted 16 February 2014 - 10:27 PM
