hi all i would prefer to sell all of this as a job lot and get rid of it all at once with collection only from YO26 York. i want to do collection only as to send it all will be hard due to the weight but also because most of it is flammable. any way here's pics of everything i have, pretty much everything you need consumables wise to spray and entire mini. please note all of this stuff is high quality stuff and is quite expensive to buy new, please note everything is new unless stated otherwise
list of what's included:
1 litre of diamond white cellulose paint (enough to spray a roof and other little bits if required)
2.5 litres of flame red cellulose paint (just enough to spray the rest of a mini)
5 litres of cellulose thinners (i'm sure i have another 5 litre can somewhere so if i can find it, it will be included)
3m respirator, package opened but respirator unused
silverline disposable overalls
masking paper, i can't remember how long it is but i think there is easily enough for a mini.
paint mixing cups, only small ones but will be included
clarke pro 14C (i think this is the model) paint gun with an add on water filter
5 litres U-pol degreaser
2x 1 litre of self etching primer
2x 1 litre of self etching primer activator
5 litres of u-pol P88 high build grey primer
1 litre of brushable seam sealer
3x 1 litre of hammerite stone chip shield shutz in grey, can be painted over, will make a great job of shielding the underneath
1 litre of black por 15, approx 3 quarters, maybe half a tin left.
1 litre of por 15 tie coat primer, basically a primer that you spray onto por 15 and you can then spray any colour on top of that
4 litres of por 15 marine clean, opened but probably about 3.5 litres left
4 litres of por 15 prep and ready, again opened but probably about 3.5 litres left
250ml hammerite smooth red paint
750ml hammerite satin black approx half full
500ml hammeriite brush cleaner & thinners
250ml hammerite kurust
there is over £200 in the paint, thinners, por 15 & upol p88 alone. i am looking for £125 collected from YO26 York
thanks
