looking to have my 1275 bored to 1310
can anyone tell me the best place to get pistons from quality for money wise?
and am I doing the right thing going to 1310?
Posted 17 February 2014 - 11:26 PM
Posted 17 February 2014 - 11:30 PM
It is normally considered best to always go to the next size up when re-boring, so in this case it's +0.020" which gives 1293 cc.
Pistons should be 21253-020 from Mini Spares and always take the pistons to the machine shop so that the bores can match.
Posted 18 February 2014 - 12:54 PM
It's always worth chatting to the guy who's doing the machining. He suggested that I got the pistons as his supplier was likely to be more expensive! Don't forget if you use TMF+ discount (7.5%) at Minispares, that's a decent chunk of cash off!
Posted 18 February 2014 - 01:05 PM
As stated above, always take the pistons with you!
Posted 18 February 2014 - 01:06 PM
Posted 18 February 2014 - 01:16 PM
Posted 18 February 2014 - 01:18 PM
Posted 18 February 2014 - 01:20 PM
Posted 18 February 2014 - 01:27 PM
Posted 18 February 2014 - 05:44 PM
Edited by ACDodd, 18 February 2014 - 05:44 PM.
Posted 18 February 2014 - 05:52 PM
Hang on your missing the point a straight rebore and fresh pistons add power regardless of size. This is because you restore the original piston ring/bore finish and can now hold the ring squarely in the bore. This means an increase in seal compared to the worn original. So a rebore adds power. The mistake you making is assuming that the original old bore and rings is as good as new. Which of course it is not. The old setup is costing you power.
Ac
What I was saying is, it doesn't increase power output - it just restores what might have been lost if the current setup is extremely worn.
Posted 18 February 2014 - 05:58 PM
Posted 18 February 2014 - 06:11 PM
That's true actually, extremely was probably the wrong word.
Posted 18 February 2014 - 08:08 PM
Great topic guys and all very good advice BUT please dont forget to let this guy know that the more you bore it out ie 1380/1400 he will have to upgrade the rad because it will run hotter due to the bore walls being thinner,many a big bore have been totaled because a standard rad has been used..
Posted 18 February 2014 - 08:13 PM
If shopping for 21253 pistons try your local motor factors - 21253 is the old ref for them - but an accepted norm - but a bit of research and you'll get the right reference they're Nural now - (as a starter mine at +60 are parts ref 87-524114-00) local place got me the set in for £130.....
