Hi;
As the title states I am in the process of removing the Radius Arms in an attempt to see what I can salvage from my Subframe.
So far I have been lucky with removing bolts and nuts having follow advice and pre soaked with WD40 and 3 in 1 Oil (Just found out about Plus Gas).
It looks like the Radius Arm is held in place in two locations, at the outer edge of the subframe by a plate secured by 4 x bolts holding and by 1 x Nut inside the Subframe.
Firstly these two bolts (shown in the bottom LH of the pic) are easily accessible and OK:
However due to the location of these 2 x Bolts and the close proximity to the Radiius Arm I cannot get a socket, standard spanner or ring spanner onto it? What tool is required to undo these two bad boys:
Can someone give me some pointer on removing these troublesome bolts.
This is, I guess, the nut securing the inner side of the Radius Arm, the one located just above the brake pipe union, this looks trouble some in this pick but once the undersell and other gunge was wiped off it came off easily.
I have soaked the Flexile Brake Hose connectors because these also have to be removed in order to remove the Radius Arm from the Subframe however, they look and probably are pretty solid so I may end up having to cut them off - any tips to get them off without damaging the mounting on the Radius Arm?
The rubber at the joint on one of them is split so I'll definitely be renewing them anyway:
I take it you have to undo the nut on the opposite side of the bracket on the Flexi Hose?
Believe it or not the bullet shaped nut on the copper brake pipe actually turns? But on one side the copper brake pipe is stuck inside the nut, a replacement set of copper pipes is only £7 on Ebay from Richmond Classics and a full set with flexes is £38.
Any advice on the above would be great.
