Mini Idle Speed
16 replies to this topic
#1 lukesanders
lukesanders
  • 157 posts
Posted 18 February 2014 - 05:53 PM
What is a good running idle speed for a mini to help performance etc?
#2 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 18 February 2014 - 05:54 PM
Just so it runs without struggling, idle doesn't affect performance
#3 Andy!
Andy!
  • 481 posts
  • Local Club: N/A
Posted 18 February 2014 - 05:55 PM
Yeah you're not going to notice any performance gains from a faster or slower idle. IIRC a good idle is around 800-1k rpm
#4 lukesanders
lukesanders
  • 157 posts
In regards to RPM what should it be with the choke in?
#5 minimender
minimender
  • 1,589 posts
Posted 18 February 2014 - 05:58 PM
I would say round about 800 but as long as the engine idles nicely and doesn't struggle then what ever you want
#6 lukesanders
lukesanders
  • 157 posts
Posted 18 February 2014 - 07:05 PM
I'll change it at the weekend, thank you
#7 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,032 posts
Posted 18 February 2014 - 07:06 PM
I Think it say 750 rpm in the haynes manual for my 998.
#8 lukesanders
lukesanders
  • 157 posts
Posted 18 February 2014 - 07:11 PM
Is there anyway to accurately measure this, other than the clock in the dash?
#9 jelboy89
jelboy89
    Formally known as jr4sr4eva
  • 169 posts
Posted 18 February 2014 - 07:57 PM
Believe it also says +/- 50 rpm
#10 jt19
jt19
  • 745 posts
Posted 18 February 2014 - 10:06 PM
If you've got a modded engine with a lumpy cam in you'll struggle get it to idle that slow
#11 Craig89
Craig89
  • 600 posts
Posted 19 February 2014 - 06:16 AM
Also when you have the lights on, or any other electrical devices, this will drag the rpm down so I set it at about 900 rpm with everything off
#12 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,857 posts
  • Local Club: man Estate
Posted 19 February 2014 - 11:13 AM
IMO you don't need numbers for this, just the slowest comfortable idle will be right.
#13 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 19 February 2014 - 12:26 PM
The idle with the choke fully out is higher anyway, set the idle speed to 800 RPM with the choke in.
#14 silver_toes
silver_toes
  • 364 posts
  • Local Club: None
Posted 19 February 2014 - 12:54 PM
What's a good idle speed for an mpi 1275 ?
#15 HarrysMini
HarrysMini
  • 3,352 posts
Posted 19 February 2014 - 12:58 PM
I don't believe you can adjust that, can you?
I you can, again, 800 RPM.
