I may be a little controversial here - but what’s with the fascination with spraying WD40 on everything? There are two starting threads currently running on here and both have the same suggestion, neither made a difference.
I've never tried it and never felt the need to when trying to find a starting problem. If it's not starting there usually something pretty basic wrong and even with a gaping vacuum leak and/or crappy fuel you'll generally get some indication of life if all other elements are equal.
I'll put it another way - the lump I have out in garage fired with both the vacuum advance and oil breather line open while being fed rather yellow 2+ year old fuel.
And to take it one further - we ran an A-series with no carb, just pouring a trickle of fuel into the manifold from a jam jar!
So before farting about with everything else - check it's getting fuel, check its getting a spark and it's happening at the right time and the very basic that the source of power (jump pack/battery/charger) has enough juice to crank with compression (i.e all the spark plugs in) and fire the coil, I've been caught out by that last one more than once!
edit: Sorry, that's a bit ranty!
Edited by Icey, 26 February 2014 - 09:16 PM.
