Had a fuel issue last week and I have noticed this before but the fuel line is less than an inch from the hot manifold. IS this normal/dangerous and is there any kind of shield one can get to separate the two.
Many thanks
zeroasylum
Posted 20 February 2014 - 08:33 PM
Many thanks
zeroasylum
Posted 20 February 2014 - 09:04 PM
This is normal on some mini's - but not good in my eyes , & I have gone over to an electric pump for this very reason
you could get some heat shield wrap & wrap the pipe & the exhaust where it is close (not ideal)
the bit that annoyed me was the pump outlet pointing towards the exhaust
some older pumps had movable outlet / inlet , but newer ones were crimped in position
I would also be interested in solutions to this , as not keen on the electric pump
Posted 19 March 2014 - 02:28 PM
Unfortunately this is something you have to live with having a Mini.
Not a lot of choice, that is why the outlet to carb should have a small amount of rubber pipe connecting the metal pipe to the carb. An inch and half of rubber pipe then the metal should be fine, otherwise it is use the electric pump option, not much choice.
Posted 21 March 2014 - 02:32 AM
Thanks for the reply. I am curious of opinions on this. I have braided stainless steel rubber hoses at the rear tank. Can I use this hose to replace the ones at the carb and fuel pump or is straight rubber ones best.
Many thanks
Zeroasylum
Posted 21 March 2014 - 08:43 AM
Posted 21 March 2014 - 09:04 AM
The best would be replacing the early type mech fuel pump with the later type used on HIF44 carb'ed coopers, these pumps will make you fuel line easily clear any aftermarket LCB exhaust.
As above, retain the steel fuel line.
