Turns Over But No Spark
10 replies to this topic
#1 mini-babe
mini-babe
  • 16 posts
Posted 22 February 2014 - 01:10 PM
hi would really appreciate some help, the mini I currently have has always been very temperamental and at the moment wont even start!
Before I had the problem ive replaced:
dizzy cap
leads
plugs
rotor arm
battery
alternator
starter motor
prob a few more things but all I can think of to do with this problem...
then since it has failed to start I have tried
a new coil
change of leads
change of black gubbins box (top left engine bay)
all still to no success.
ive worked out
that I have fuel getting to the carb..
im getting power to my dizzy (as set me wire wool on fire when cleaning it lol)
and im reading power through the coil on a volt metre although I do understand motor electronics are slightly different.7
ive tried a fault finder on it but I cant even get it to read anything and im not sure why??? (just keeps saying unable to establish data connection)
really really struggling now what this could be and don't really want to take it in a garage to get ripped off if it is something I could fix... im just hoping its not the ECU although it seems to be pointing that way.
#2 Dusky
Dusky
  • 5,322 posts
Posted 22 February 2014 - 02:37 PM
Test for spark at the plugs and check if the plugs are wet after cranking.
#3 mini-babe
mini-babe
  • 16 posts
Posted 22 February 2014 - 03:12 PM
I have checked that's how I know there's no spark at plugs.
and plugs r wet
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,376 posts
  • Local Club: Amoc
Posted 22 February 2014 - 03:31 PM
What year is the car in question?
#5 mini-babe
mini-babe
  • 16 posts
Posted 22 February 2014 - 03:54 PM
1997 equinox
#6 mini-babe
mini-babe
  • 16 posts
Posted 25 February 2014 - 05:06 PM
Bump?
#7 Dusky
Dusky
  • 5,322 posts
Posted 25 February 2014 - 05:15 PM
measure if you have energy at the coil with a multimeter.
Sometimes a condensor comes faulty out of the box ( like mine)
Also, check that everything is installed correctly ( eg right power supply on coil, right connection to condensor,..)
grtz!
#8 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 25 February 2014 - 05:19 PM
I would suspect the crank sensor
#9 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 25 February 2014 - 06:31 PM
Immobiliser problem?
#10 mini-babe
mini-babe
  • 16 posts
Posted 27 February 2014 - 06:10 PM
Checked with multi metre and I do have power at coil. Also Yeh have checked everything is where it should be.
Wouldn't no about crank sensor, how do I know?
Can't be immobiliser as it wouldn't turn over at all would it?
#11 mini-babe
mini-babe
  • 16 posts
Posted 02 March 2014 - 05:51 PM
Turned out to be snapped corroded wires going into ecu. :-( not lookin forward today this fix lol
