Wired Up Battery Wrong Way
7 replies to this topic
#1 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 22 February 2014 - 06:29 PM
Hi all anyone help , Only gone and wired up me car battery the wrong way think I have blown up the alternator as i am only getting 12v at the battery and red light on dash will not go out . The alternator is not that old . can it be fixed ?
any help will be gratefull
thanks
#2 tiger99
tiger99
  • 8,584 posts
Posted 22 February 2014 - 06:40 PM
It will be far cheaper, quicker and easier to just swap it for a reconditioned alternator, available just about anywhere. The diode pack is guaranteed to be fried, the regulator probably too, and the windings, which can't easily be replaced by yourself, will have been very seriously overheated, and very likely to fail or develop a short-circuit at any time.
This has happened before on the forum, more than once, and I am curious to know how it can happen, as the battery terminals are usually different sizes, as well as the leads normally being too short to make wrong connection possible.
#3 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 22 February 2014 - 06:57 PM
thanks for your reply , yes the -  terminal did not fit but it did touch
#4 tiger99
tiger99
  • 8,584 posts
Posted 22 February 2014 - 07:03 PM
I see, it only does need a touch, and it would be better if the terminal design made such touching impossible. Sadly, we are where we are, and I can't imagine the terminal design being improved, although on more modern cars, with hideously expensive dual-voltage batteries, the problem may have gone away.
#5 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 22 February 2014 - 07:12 PM
thanks
I did this  :shy:  when not paying attention, but I got away with replacing the blown fuses, I was v. lucky but worth a check.
#6 tiger99
tiger99
  • 8,584 posts
Posted 22 February 2014 - 07:15 PM
You were VERY lucky!
#7 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 22 February 2014 - 08:30 PM
same as OP, just a touch before realizing mistake, sweaty palms moment
#8 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 23 February 2014 - 12:35 AM
I did this too recently, but sadly didn't realise until the loom had caught fire! Luckily I managed to stop the whole car (and the garage it was in at the time) going up in flames. Bizzarely my alternator actually survived the ordeal, but having now fitted a replacement loom, it was still a rather expensive and time consuming mistake to put right!!
