will a bej needle work in a 998 with a hif44 carb? thanks ![]()
Bej Needle In 998
Posted 22 February 2014 - 07:41 PM
Posted 22 February 2014 - 09:08 PM
Will depend on you engine's spec's...
Maybe stating them would help :)
grtz!
Posted 22 February 2014 - 09:24 PM
Get yourself winsu for the most likely candidates if you're determined to use a '44.....
Posted 22 February 2014 - 09:34 PM
Most of the time u can guess what needle you need though WINSU doesn't show th elast letter unless U pay
Posted 23 February 2014 - 12:18 AM
Hif44 to big unless the engine in a very high state of tune, but have far better response on a 1 1/2 than the bigger carb.
Posted 23 February 2014 - 01:06 PM
Annoying thing is I dont know how tuned the engine is. Its all electronic ignition with no vacuum advance on dizzy, rebuilt engine to 1000cc high compression, Head work, cone filter, maniflow manifold and exhaust system, external electronic fuel pump etc
Will try that software and see what it says
thanks
Posted 23 February 2014 - 01:17 PM
Do you know what exhaust etc?
When it has an electronic ignition without a vacuum check for any serial numbers on the dizzy..
Probably a fast road dizzy or a programmable unit wich means the engine is tuned( most road engines still have a vacuum)
Posted 23 February 2014 - 07:30 PM
When we were referring to the state of the engine tune, we should have been more specific, this would have to be a competition engine to use a HIF44 to its best
For example its a known fact that for every 1bhp a engine needs 2-2.2 cfm of airflow, so using the known formula we take the cfm of a HS4 1 1/2 SU which is 142cfm in standard form,
So 142cfm divide by 2 =71bhp
So a engine wont be restricted by a 1 1/2 SU until after that bhp figure, so our 998 engine will be in a high state of tune to need a HIF44 which using the formula will provide enough cfm for 120bhp.
But you have to remember that where the secret to BHP on the A Series heads is in the head, and standard heads are not good a cfm airflow, so its not all down to how big is the carb and what will it flow, its always down to where is the biggest restriction and what is the cfm at that point.
People with greater knowledge than me like AC and Cooperman can explain it fully.
Posted 23 February 2014 - 09:16 PM
This! - think you pretty much nailed it!
Posted 23 February 2014 - 09:31 PM
you need a rolling road session regardless so i would just worry about getting it there to be honest.
Posted 23 February 2014 - 10:08 PM
