My 850 1979 Austin Morris has quite a rattle around the timing chain. I've not removed the cover yet, and was looking on Minispares for the tensioner so I can replace it but can't find one for an 850. Could those in the know tell me whether the 850 has a tensioner fitted please, and if so where I could purchase one ? Thanks in advance.
Timing Chain Tensioner
Posted 22 February 2014 - 08:47 PM
Posted 22 February 2014 - 09:10 PM
Probably no tensioner, but you can buy one and install one.
Will need another timing cover.
grtz!
Posted 22 February 2014 - 09:15 PM
So ....it depends on when your engine was built......
Posted 22 February 2014 - 11:40 PM
Ok many thanks. I'll take off the cover and check first then.
Posted 23 February 2014 - 01:15 PM
Goodluck :)
Posted 23 February 2014 - 01:29 PM
The covers are different shapes so you shouldn't need to remove it to find out.
Posted 23 February 2014 - 04:31 PM
Thanks. Yes I realised this earlier when comparing it with my 1990 City E I'm restoring. They are both the same (late type covers) so I reckon my 79 will have a tensioner. I'll order a new tensioner pad and replace the worn one to see if it resolves the rattle. Thanks very much for your help chaps.
Posted 23 February 2014 - 07:02 PM
If your fitting a tensioner pad to cure a rattle, its false economy not to fit a new timing chain, you may silence it for a short while but it will return, trust me!
Posted 23 February 2014 - 07:18 PM
In more than one sense, it'll cost you mpg too.
Posted 23 February 2014 - 07:34 PM
I did wonder after looking at some past posts. I see you've given this advice before. Thank you for your guidance. I've added a new chain to my order.
Could I ask, for a standard 850 would it be beneficial to fit a duplex kit instead. I will still fit the new tensioner as I noted that aspect from your historical posts too.
Posted 23 February 2014 - 11:20 PM
Posted 23 February 2014 - 11:42 PM
Its not as black and white as Duplex does not use one, and single row chain does use a tensioner, I always use a tensioner and so do respected tuners including our own specialist AC Dodd. Some say it fails but none have done on mine even though it runs centre of the duplex. Duplex chains eventually stretch.
Posted 24 February 2014 - 08:07 PM
Posted 24 February 2014 - 08:46 PM
Yes more accurate cam/ignition timing and longer service between chain replacement
