Posted 23 February 2014 - 11:39 AM
The car is the basic 848cc super deluxe engine with standard gearbox.
Many thanks, Tom.
Posted 23 February 2014 - 11:46 AM
Some people just say careful driving increasing the revs every couple hundred miles
Or...
Just drive it normally/spirited
Up to you both are proven
Edited by coopdog, 23 February 2014 - 11:47 AM.
just curious who said 30mph ?
seems a bit low & may load the engine a bit too much - which you don't want when running in
more important to vary the revs , & keep the load light & light on the throttle
I would say more like 50 mph (in top)
Edited by sledgehammer, 23 February 2014 - 11:50 AM.
Posted 23 February 2014 - 12:04 PM
so the rings bed in properly.
Posted 23 February 2014 - 12:18 PM
These are the running instructions from the 1963 Austin Mini Handbook
Running-in Speeds
The treatment given to a new vehicle will have an important bearing on its subsequent life, and engine speeds during this early period must be limited. The following instructions should be strictly adhered to.
During the first 500 miles (800km)
DO NOT exceed 45mph (72kph).
DO NOT drive at full throttle in any gear.
DO NOT allow the engine to labour in any gear.
Also I would advise re-torqueing your head down after a couple of hundred miles and change the oil and filter after you have run the engine in.
Posted 23 February 2014 - 12:40 PM
Good advice to run it on a light throttle at all times, revs wont hurt it as long as you don't rev it too much, better to use more revs than normal on a light throttle than low revs with your foot down.
Also frequent short journeys are better for running in than say doing 500 miles all at once
Posted 23 February 2014 - 08:17 PM
Hi there, I am just coming up to getting my 1963 mini on the road and with reguards to running the engine in, I have to drive 500 miles at 30 mph. My question is, roughly what rpm is the engine doing at 30mph?
Many thanks, Tom.
Depends on what gear your in
Posted 25 February 2014 - 12:32 AM
Thanks again, Tom.
Posted 25 February 2014 - 12:42 AM
I'd do the same, just a bit of mechanical sympathy - moderate the revs and don't let it lug. It's not only the rings and bores that you are running in.
Posted 25 February 2014 - 06:41 AM
Also tagged with one or more of these keywords: engine, suspension
Mini Technical Sections →
Problems, Questions and Technical →
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
