Polyurethane Bushes V Rubber Bushes
Posted 23 February 2014 - 12:38 PM
Apparently poly can be good for certain parts of the car to replace the oe rubber spec,but on other parts,say like the front bump stop, there saying do not use poly as they are a lot harder and will not absorb being hit, and to always use rubber ones.
They also mention, as pressure is applied on certain areas of bushes,that the poly will expand and not contract over time, unlike rubber which will leave any poly bush loose on the shaft.
I already have these fitted in places where they mention not to use poly, so wondering now if to replace them for oe rubber.
Anyone else got any thoughts on this?
Posted 23 February 2014 - 12:54 PM
The only place you should need to fit poly bushes is the rear subframe, bumpstops should never be poly as you rightly say, they don't absorb anything.
For the front subframe, either solid or rubber.
Most poly bushes made are actually of very bad quality so they can fail prematurely and quite suddenly.
Posted 23 February 2014 - 02:57 PM
This is meant to give enough flexibility but firms things up!
I've never used it though
Posted 23 February 2014 - 02:59 PM
Posted 23 February 2014 - 03:02 PM
Tie rods...i have the half n half kit fitted
What's it like compared to standard?
Posted 23 February 2014 - 03:04 PM
Posted 23 February 2014 - 03:42 PM
I wouldnt fit poly to the bottom arms. They distort and then the car starts to wander. I had this issue with mine as the previous owner had replaced every single rubber bush with poly.
Posted 23 February 2014 - 03:59 PM
Posted 23 February 2014 - 08:21 PM
I have all the front and rear poly bushes for my mini, and i am planing to install them tomorrow, am i making a mistake buying them and spending the money ? ,
Which bush do you recommend me to replace with poly and which dont ?
Panayiotis
Posted 23 February 2014 - 08:22 PM
Hi,
Panayiotis
Replace the rear subframe with poly
Posted 23 February 2014 - 08:26 PM
My rear subframe is poly bushed, was like that when I got it.
ive fitted standard rebound rubbers, standard bump stops. The half poly half rubber tiebar kit. Front subframe is solid mounted.
New standard knuckles, coil springs and gaz adjustable shockers.
I need to do the lower arm bushes, these will be done in standard rubber too.
Posted 23 February 2014 - 09:30 PM
