What Needle For This Setup?
12 replies to this topic
#1 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 23 February 2014 - 07:18 PM
What needle should I have for this setup?
1984 998
HiF38 Carb
Maniflow Manifold
Maniflow Full single  exit system
Rebuilt to high compression 1000cc
K&N Cone filter
Electronic Aldon ingnition / distributer (without a vacuum advance)
I think Metro inlet manifold
Electronic fuel pump set to 2.5psi
Previous owner said something about head work but wasnt 100% sure on what was done
#2 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 24 February 2014 - 04:20 PM
Does an AAA sound right?
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 February 2014 - 04:44 PM
AAA is a 1275 needle so possible a bit rich for a small bore engine, you seem to be running the standard cam from your spec. here are some popular needles ABY might be nearer what you need
ADE
998cc, HIF38, Metro inlet, std filter, free flow exhaust
ABY
998cc, 12G295 head, HIF-38, Stub Stack, K&N, 3 into 1, RC 40, std cam
AAU
1100cc, 1.5in SU, 3into1, heated inlet, RC40, K&N
AAA
1275cc, HIF38, 9.5:1CR, conical filter
#4 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 25 February 2014 - 09:21 AM
Going by the code on the Aldon dizzy and the aldon site the engine could have Piper 270/285 or Kent 266/276 / 286 cams fitted...
#5 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 25 February 2014 - 09:44 AM
Going by http://www.mintylamb.co.uk/suneedle/
is the ABY Richer than the AAA needle?
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 February 2014 - 11:33 AM
Yes it is from around position 5 on the needle, the AAA for the 1275 is only a std engine with a conical filter, where as the spec of the 998 listed has a better exhaust + other mods, as with all needle charts there only a guide and lots require a custom needle to suit.
#7 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 25 February 2014 - 12:25 PM
Ok, I already ordered the AAA needle last night, if its no good I will go with the ABY or AAM
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 February 2014 - 07:29 PM
Thats the learning curve on needles and you have to try what works or modify as required
#9 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 26 February 2014 - 07:19 AM
Aaa aam aby seem to be popular from what i have seen after hours of googling
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 26 February 2014 - 10:42 AM
In most cases the AAA needle is too rich for a st1 998 mini. I find an ABD needle a good starting point, this then needing some custom tweaking to dial it in. Most engines need a custom needle to get the best from them.
AC
#11 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 26 February 2014 - 11:59 AM
I looked at ABD but it seemed near the same as AAU which people said was for stock airbox with k&n element and too lean for a cone filter
#12 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 26 February 2014 - 01:00 PM
Yup the AAU can also be used. It too will need mods.
AC
#13 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 26 February 2014 - 01:06 PM
AC
