To Brace Bar or Not To Brace Bar
Posted 04 June 2006 - 08:26 PM
So
Will I be able to get away without fitting the brace bars for Mr MOT? Or, am I going to have to fit them?
Posted 04 June 2006 - 08:29 PM
the front end is more held up by the subframe than the front end stopping the subframe move around.
Wil
Posted 04 June 2006 - 08:44 PM
Mainly because the inner wings have been removed. The brace bars give that strength back through triangulation
Posted 05 June 2006 - 06:30 AM
I would deffo go with brace bars if there is any doubt. An MOT tester has to decide on the spot whether or not the structural integrity has been altered.
Personally, I think it needs em too
Posted 05 June 2006 - 06:48 AM
dave
Posted 05 June 2006 - 06:53 AM
Imagine you have a fully built up mini (standard in every way), but the front subframe mounts are missing. Now, you need to jack it up. Would you jack it on the subframe or the front valance, and if you jacked it on the valance what would you expect to happen to the the rest of the front bodywork (accepting the fact that the valance would be damaged).
Thr front bodywork on a a mini is non unitary and with solid rear mounts bracebars do very little, even with the front end removed.
Posted 05 June 2006 - 07:38 AM
If you look at it from an MOT testers point of view, he is just gonna look at it and say 'the inner wings have been cut out, that must've compromised the structure'
Exactly what i was going to say. From an MOT testers view he will see no brace bars and no inner wings and see it has a srtuctual failing i reckon.
Isn't Marc an MOT tester? maybe he will be able to give a definitive answer
Posted 05 June 2006 - 10:33 AM
Posted 05 June 2006 - 09:45 PM
Oh and where exactly will the wings crack??
Posted 05 June 2006 - 10:10 PM
Posted 06 June 2006 - 06:02 AM
As for the necessity... A mini without support for the front of the subframe will fail an MOT, ie original mountings not there... The inner wing forms part of the ridgid structure to support the front subframe. Remove the inner wing, you will need bracing of some sort..
If the inner wing had a rusty hole in it, you would be failed on corrosion within 30cm's of a mounting point.
Posted 06 June 2006 - 10:42 AM
Posted 06 June 2006 - 12:04 PM
