Foam In Engine Bay
30 replies to this topic
#1 Thilemann
Thilemann
  • 45 posts
Posted 25 February 2014 - 09:28 AM
Hi All.
I just welded my new front on yesterday, and are now almost ready to put the engine back in. But In my engine bay there is some kind of foam, which is up in the top against the cabin. Is'nt this just collecting a lot of dirt and moist? I'm thinking of removing it, but i'm not sure if it's ok.
The picture below is not taken for this purpose, but just one i found which i took earlier, but should show what i mean.
#2 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 25 February 2014 - 09:43 AM
Just remove it, only collects dirt and looks crap. (not sure on this but Im sure some contain asbestos so be carful)
#3 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 25 February 2014 - 09:47 AM
It's a foam type insulation, supposedly to reduce noise, some people like it, some don't . You can get a replacement if you don't like the look of a bare bulk head.
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 25 February 2014 - 10:29 AM
It doesn't really do a lot for soundproofing anyway, the insulation on the inner side of the bulkhead is much more effective at that. I'd remove it because it absorbs moisture and any rain water that gets into the engine bay, which in turn corrodes the back of your fuse box.
#5 Gadgets
Gadgets
  • 471 posts
Posted 25 February 2014 - 10:38 AM
Rust generator in my opinion remove it!
#6 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 25 February 2014 - 11:00 AM
I took mine out. Makes the engine bay look a lot better and I didn't notice any additional noise! The only bit which was fiddly I think was the fuse box, as I had to take that out. But at least it's not rusting behind it anymore.
#7 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 25 February 2014 - 11:02 AM
remove it! i have, and when i checked my fusebox earth it was corroded, so i changed it and havent had any problems since!!
#8 Thilemann
Thilemann
  • 45 posts
Posted 25 February 2014 - 11:18 AM
Thank you very much. It will be the first thing i do tomorrow. Should be easy with the motor out. Noise shouldn't be any problem, because my front exhaust has been broken since i bought it, and have bought a replacement. So noise will be less anyway :)
I have been lurking a lot in here, and are planning to make a build thread. Great forum for a newbie like me!
#9 Dusky
Dusky
  • 5,322 posts
Posted 25 February 2014 - 08:34 PM
Asbestos in sound isolation?? Never heard of that one.. doesn't even need to withstand high heat...
#10 lewBlew
lewBlew
  • 1,238 posts
Posted 25 February 2014 - 11:14 PM
Surely no asbestos in an 80s/90s car? I think it's just spongey foam.
#11 Dusky
Dusky
  • 5,322 posts
Posted 25 February 2014 - 11:22 PM
Clutch and brakes can contain it..also headgaskets.
Sound proofing is a plastc spayed with a 'anti rain coating'
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 February 2014 - 11:58 PM
Not here in the UK here anymore brake linings, clutches, and in gaskets. The use of asbestos in these components was prohibited from 1999
#13 Dusky
Dusky
  • 5,322 posts
Posted 26 February 2014 - 06:28 AM
Yea, im Belgium it was 2000 orso.. but I think there are still alot of minis that have their original clutches and headgaskets...
#14 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 26 February 2014 - 09:23 AM
Hence why i said "not sure"  ;D  going off the thought most other things in the engine bay did contain some.
#15 Dusky
Dusky
  • 5,322 posts
Posted 26 February 2014 - 12:38 PM
Yeah, true ^^ Just changed half my engine bay , all with asbestos free products ^^ ( kinda creeped out by that stuff to be honest)
