cradley-heathen,
I understand why you will not name the garage, however my intention is not to get a classic-friendly garage to pass something that should really fail (I am very much against that), but rather to avoid getting into stupid disputes, and appeals to VOSA, when a garage without recent classic experience fails something that should actually pass. I also expect that a car that is unsafe should be failed, although sometimes thay are not, due to limitations of the MOT test. The point of the MOT is, or should be, to prevent unnecessary accidents, incidents,injuries, damage and pollution.
A common example used to be the lower ball joints on the front suspension of older Vauxhalls. The joint is always under tension, because the spring/damper acts on the lower wishbone, and an end float of over 0.1" is allowed, in fact the end float of a new joint was not closely set during manufacture because there was no need. (Think of a Mini knuckle joint, that is always under compressive load.) The correct check involved an external measurement with a simple gauge, to see if the ball had sunk seriously into its seating. (In case of severe wear it could pull through, with potentially fatal results.) However, MOT testers frequently jacked the car up, and used a crowbar between upright and wishbone to assess free play, and promptly failed it, even if the ball joint was brand new. I never owned one of these cars, and don't like them, due to stodgy handling, but I knew people who did, and they soon realised that if they went elsewhere than to a Vauxhall garage there was a good chance of a bogus failure. Now, even Vauxhall garages will have lost the knowledge...
