Wings have to be removed to do this properly however you may have done this already
When you have the scuttle panel use it to mark where to cut on the pillars make sure you only cut the scuttle panel though
Then drill the spot welds out along the top lip and remove the panel you will be left with to scuttle close out panels either side which will probably be non existent or badly rusted these need to be removed
I would then clean up any rust issues and place the scuttle panel in place and roughly clamp it on where possible, then refit your bonnet and clamp the new wings into place and play around with them all until your happy with the shut lines of the bonnet to the wings and bonnet to the scuttle joint
MAKE SURE YOUR BONNET STILL OPENS OVER THE SCUTTLE
Then spot or plug weld the scuttle to the lip and seam weld to the pillars and clean up with the grinder, fit your scuttle close out panels and fit the wings permantly in place
Make sure you buy a genuine or heritage panel as the pattern ones just don't fit so don't waste your money on them
Edited by corrado vr6, 28 February 2014 - 10:27 AM.
