Afternoon all,
Time to fess up to an amateur mistake I made yesterday & ask for some advice on how to fix it.
So the story goes;
I've got a leaking rod selector seal, ordered a seal repair kit from MS & read the section in the Haynes manual many times to know exactly what to do. Got the car jacked up, found the correct socket to undo the oil drain plug & set about undoing it. It was stiff to start with but soon freed up & after a short time I stopped to check progress, to find it wasn't coming out. At that point I realised I had been turning the plug the wrong way & I'm pretty sure I've screwed the thread off.
(Silly mistake I know, but I'm sure everyone's done something similar as a learner, right?)
Anyway, I tried to pull the plug out with mole grips, but it wouldn't budge. Its still quite tight so I've decided to leave it alone for now & haven't driven the car since.
So my questions are;
- Which thread have I knackered - The plug? The sump/gearbox casing? Or both?
- Will the car still be safe to drive? With the engine running will the oil pressure blow the plug out or is it an unknown factor?
- What is the best method of going about fixing the mess without making it worse?
For reference, its a completely standard 998cc motor.
Thanks in advance.. Needless to say I'm still feeling pretty angry with myself for doing it
