Spotlight Fuse
6 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 01 March 2014 - 11:33 PM
Im looking to wire up my spot lights but what fuse would i use to wire it up to the relay? i have the standard 4 fuses as pictured below but which one will i use to wire up my spots?
$(KGrHqVHJC8FCcCn2ghOBRRkQfk26w~~60_35.J
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 02 March 2014 - 12:15 AM
None of them, they can't take it. You need to create a new fused circuit from the main supply terminal at the solenoid. There are lots of threads here describing exactly how.
#3 Ethel
  • 25,997 posts
Posted 02 March 2014 - 12:17 AM
The operating side should be tapped off the blue/white main beam wiring, draw your power supply directly from the solenoid, where the other brown live feeds start. You can earth the operating coil via a switch to turn them off if you just need high beam.
Terminals:
30 - feed (solenoid)
85 - earth (via switch)
86- blue/white (high beam)
87 - to your spots
An addendum Dan would approve of: adding things to existing fused circuits can increase the risk of your electrics catching fire.
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 02 March 2014 - 12:46 AM
Im on my kindle at the moment and it wont let me search can you post a link up please how to create a new fused circuit there must be a bug it wont let me search
#5 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 02 March 2014 - 12:51 AM
Terminals:
87 - to your spots
Right wont do that i dont want that to happen
#6 welldc
welldc
  • 92 posts
  • Local Club: Robin Hood Mini Club
Posted 02 March 2014 - 02:18 PM
Mini Spares do a kit to wire them in properly:
http://www.minispare...px|Back to shop
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 March 2014 - 03:41 PM
Here you go, terminal 30 in the Minis case will be the brown feeds of the solenoid
Edited by KernowCooper, 02 March 2014 - 03:43 PM.
