Went to try and adjust my rear brakes this morning and the nut is completely seized! I've got the right size square spanner, used some plus gas on the damn thing but to no result....slightly worried I'm gonna graunch the thing. Any ideas?
Brake Adjustment Nut Seized Up
Posted 02 March 2014 - 12:13 PM
Posted 02 March 2014 - 12:16 PM
Have you tryed tightening and loosening, tightening and loosening... ?
Posted 02 March 2014 - 12:19 PM
This worked for me so defo try it
Posted 02 March 2014 - 01:22 PM
won't tighten or loosen! Wont budge! Carlos, what should I soak it in? Slightly difficult when its still on the car!
Posted 02 March 2014 - 01:41 PM
Penetrating oil, from both sides! So its drum off, shoes out!
Posted 02 March 2014 - 03:07 PM
Pain! And its just started raining! ![]()
Posted 02 March 2014 - 03:36 PM
If that fails then Halfords do a brilliant spray called shock and unlock, its a combination of penetrating oil and a freezing action. It 'cracks' the rust. When you get it moving it will be worth taking some time to get it going freely and then use a little copper slip on the threads.
Posted 02 March 2014 - 05:52 PM
