Installing Gaskets - Should I Be Using Gasket Sealer?
Best Answer sledgehammer , 02 March 2014 - 02:15 PM
I use sealer on the half moon seal & where gaskets join in different directions
but rarely for anything else
sometimes gasket sealer breaks away inside the engine & can restrict the strainer & generally be a pain
I also used some on gear selector shaft bush (outside surface)
but some love it
Go to the full post
3 replies to this topic
#1 Bell-nose
Bell-nose
  • 137 posts
Posted 02 March 2014 - 02:07 PM
Hi,
I've stripped the gearbox, water pump, timing cover clutch housing and flywheel housing from the engine and the cylinder head.
I'm about to start putting everything back together and i've started to read they workshop manual which says nothing about using gasket sealer anywhere. I know its not standard fro Head gaskets but what about the others?
Is it standard to use gasket sealer on paper gaskets or do they self seal when tightened to the correct torque?
Thanks in advance.
#2 sledgehammer
sledgehammer
  • 3,129 posts
Posted 02 March 2014 - 02:15 PM   Best Answer
but some love it
Edited by sledgehammer, 02 March 2014 - 02:16 PM.
#3 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 02 March 2014 - 02:30 PM
Use it but don't over do it...
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 March 2014 - 03:39 PM
Hylomar is the best IMO used and made for Rolls Royce
