Urgent! Dislodged Cam Follower
Posted 02 March 2014 - 05:18 PM
I'm panicking as I dont know how to fix it and i need the car working asap.
Any help is fantastic.
Rob
Posted 02 March 2014 - 05:21 PM
Is it a 1275 unit or a 998? if its the latter then you can remove the follower cover panel round the back to investigate, if not then I dont know the easiest way to extract the follower to be honest
Posted 02 March 2014 - 05:23 PM
998? 1275?
In a 998 the tappet covers can be taken off, you'll see the follower loose and will be able to put it back in the slot. Will probably need to remove the exhaust to access it.
In a 1275 the only way the tappets can come out is out the bottom, which would require the absence of a cam.
So i'm assuming you have a 998 - take the manifold nuts off the back of the head, remove the inlet and exhaust, undo the single 1/2 inch AF bolt that retains the tappet cover.
If the cams in place they can't drop down into the engine, unless it's broken into bits that is, if it's a 998 you can remove the tappet cover on the rear of the engine and have a look.
Posted 02 March 2014 - 06:02 PM
But anyway, i went to put the pushrods back in, one wouldnt go in all the way, so i pulled it out, put it back in and it kept going
Posted 02 March 2014 - 07:00 PM
With a 998 the oil 'stiction' at the bottom of the push rod can lift a follower out of its guide. it is sometimes possible to 'fiddle' the follower back into its hole with a push rod, but you'll probably end up taking a can chest cover off. It's a simple and reasonably easy job, so don't despair.
Posted 02 March 2014 - 07:03 PM
Here's hoping its sitting happily under the tappet chest cover on can just be popped back in place....... - it's got to be in there somewhere.!!!
If you're mightily dextrous with the odd busted inset ring spanner the tappet chest cover can be taken off without removing the manifold - just..... grab a little one and engage in forced child labour....
Posted 02 March 2014 - 07:05 PM
Posted 02 March 2014 - 07:08 PM
Posted 02 March 2014 - 07:24 PM
Wisdom with hind sight, I always 'unstick' the push rod by twisting and sort of rattling to ensure the cam followers stay in place, before pulling up the push rod.
Posted 06 March 2014 - 06:35 PM
Does anyone have a detailed description of how to put the follower back in place or even a photo of what i will find behind the cover?
Thanks again guys
Edited by bigrob, 06 March 2014 - 06:35 PM.
Posted 06 March 2014 - 06:38 PM
the follower wont be in its position and you can just put it back in its disignated, place,
don`t overthink it, its very simple. when you have taken the cover off it will explain itself
freaker
Posted 06 March 2014 - 06:44 PM
Posted 06 March 2014 - 06:52 PM
no, if the cover is off its even a 20 second job :)
freaker
Posted 06 March 2014 - 06:54 PM
