So, took my 89 mini out for a drive to work. Longest distance I've driven so far! Made it to the parking lot and BAM, car cuts out after going over a bump. Try to start her up again and the battery gets drained... After work I charged the car up and started it up. Took a bit to get the car running and the engine speed was all over the place. High then at some point it would cut out unless I gas it throttle. Give it some more choke and the engine starts racing.
I then notice the smell of gas. I look and there's a decent amount of it on the ground. I traced the source to the second metal line on the top of the carb fuel reservoir (HS4). This line sortof just opens up into the air after following a metal line to, more or less, the front of the car. What is this line and why would it open up into the air? Should I assume that because gas is getting spit out of it that my needle valve is probably not working right?
Edited by dansnyderECE2010, 04 March 2014 - 06:25 PM.
