Can't Get Into Reverse
15 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 05 March 2014 - 04:57 PM
Hi all
I have changed a automatic for a manual.
I can't get into reverse but I can select all other gears
And in first the car moves but no reverse
Have any of you guys had this problem ?
Could you let me know how to fix this please.
#2 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 05 March 2014 - 05:57 PM
Dave is the clutch 100% disengaging - this can impact selecting reverse?
Will it go in if the engine is not running?  You should hear a clunk as it's selected?
If it's a rod change box is everything at the connection end with the tranny free to move?
Do you know 100% that the box worked in reverse before the swap.
Soz for so many questions ...but it may help isolate it a bit more.
#3 087dave
087dave
  • 952 posts
Posted 05 March 2014 - 07:08 PM
Tks, yes the clutch is disengaging
It will go into gear when not running
Every thing is free to move I rebuilt the box
Would it matter which way the roll pin is in at the linkage at the gearbox end?
#4 087dave
087dave
  • 952 posts
Posted 05 March 2014 - 10:00 PM
Anyone guys this is doing my head in
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 05 March 2014 - 10:05 PM
Does it grind when you try to put it in gear with the engine running, it may be the clutch is grabbing/not disengaging fully
#6 087dave
087dave
  • 952 posts
Posted 05 March 2014 - 10:13 PM
Hmmm the clutch is working fine. Yes it does grid going into
Gear but also it's moving forward !
Don't know what is going on. Maybe the gear linkage is set up wrong!
But it looks fine
#7 Gremlin
Gremlin
  • 2,142 posts
Posted 05 March 2014 - 10:31 PM
If it is going into all forawrd gears and not reverse and it is grinding, I would be looking at the clutch adsuming your gearbox has synchros on all forward gears, what clutch have you got?
#8 087dave
087dave
  • 952 posts
Posted 05 March 2014 - 10:35 PM
I have a verto clutch brand new with lightened
Flywheel
It's a 4 speed synchros
Edited by 087dave, 05 March 2014 - 10:37 PM.
#9 Gremlin
Gremlin
  • 2,142 posts
Posted 05 March 2014 - 11:33 PM
Whats the throwout nut set to, and is it working properly ie. the nut being forced up against the wok
#10 087dave
087dave
  • 952 posts
Posted 05 March 2014 - 11:44 PM
Ya that seems to be fine as I'm getting all gears, that
Is all forward gears
The grinding has stopped cause I unscrewed the
Reverse light switch, but again when in reverse it's driving forward
#11 Cooperman
  • 23,294 posts
Posted 05 March 2014 - 11:55 PM
Dave, to try to be clear, are you saying that with the reversing light switch removed it stops it graunching when you select a gear? That is strange if it's the case.
Are you also saying that when reverse is selected it is in a forward gear? If so, do you know which gear it is in?
It is going to be difficult to diagnose this remotely, but it sounds like a linkage issue inside the 'box.
#12 087dave
087dave
  • 952 posts
Posted 06 March 2014 - 08:50 AM
Hi Pete,
Ya it did stop grinding into gear when I took out the reverse light switch
I don't know what gear it's in n reverse but it's going forward
Is it possible that the gear lever mechanism of the gear change is upside down ?
#13 Gremlin
Gremlin
  • 2,142 posts
Posted 06 March 2014 - 11:32 AM
Yes but I don't think you would be able to get it in gear at all if the selector rod was upside down
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 March 2014 - 11:56 AM
When you built the box did you select all the gears dave? Watching the 1/2/3/4 and reverse slot in ? very little external which would not allow reverse to select? very odd. If you can get the roll pin out and then select the gears manually there then if it selects ok its in the remote, otherwise inside the box.
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 06 March 2014 - 12:12 PM
Silly question....
Is it a rod change gearbox ?
You know you need to lift the gearstick to get it into reverse ?
