Engine Keeps Cutting Out.
engine
4 replies to this topic
#1 0208brian1
0208brian1
  • 22 posts
Posted 06 March 2014 - 12:55 PM
hi can any 1 help,my mini cooper spi 1993,somtimes won.t  start in morning ,cuts out when moving idles on 1200 rpmi touch peddle to rev up and will die drives ok going along.but when have to stop will die starts backup ok.then starts messing about again.changed the coolant temp sensor still same. was going to change the air temp sensor next,fuel pump seems ok can be heard comin .on,drives ok if keep revs up, also in taffic just wont tick over ,please can som1h elp me, also when won,t start, will bump start ok,
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 06 March 2014 - 01:16 PM
The next things to check are the vacuum hoses, air cleaner to inlet manifold, inlet manifold to petrol trap, petrol trap to ECU. The hoses them selves are generally OK but the connections are prone to cracking or becoming loose. Blow trough the petrol trap as well, if no joy with this the wiring for the coolant temperature sender can sometimes be suspect. What's your idle speed like? Steady at about 8-900 or erratic and higher? Possible fuel filter...... Supposed to be changed ever 24000 or 2 years according to Rover.
#3 SecretSugar
SecretSugar
    Sweet!
  • 508 posts
Posted 06 March 2014 - 01:22 PM
My mpi did this. Absolutely annoying and embarrassing. Just fixed my problem, it was the exhaust manifold.
#4 emmap
emmap
    Starting My Mini Up
  • 1 posts
Posted 13 March 2014 - 11:26 AM
Hi 0208brian1 I am having exactly the same problem, I drive a Mini Cooper S 07 and so far have had most of the manifold cleaned and the high pressure fuel pump replaced but still have the same problem.
My garage has just told me that the high pressure air pump needs to be replaced, I'm a bit untrusting of any mechanics and am not sure if the diagnisis is correct. Being a small island I dont have the choice of where to send the car and am using the dealership.
Help any ideas?
Emma
#5 0208brian1
0208brian1
  • 22 posts
Posted 14 March 2014 - 09:36 PM
all sorted,bad vacuum pipes ,big thank u to everyone ,that help, l2b here will come.lol
