Clutch Failure?
12 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 06 March 2014 - 02:08 PM
This mini starts to driv eme crazy..
Was working fine last week, drove it on the fields near my house to test it a bit ( not motted atm ;) )
Today I want to move the car, I start it, I get it into gear, release clutch pedal and boom : nothing...
Any idea why?? At like 5K rpm in 1th gear the car moves a bit ( only a little)...
grtz
#2 jsiggee
jsiggee
  • 383 posts
Posted 06 March 2014 - 02:26 PM
my clutch went last year just before i was supposed to go on the East Anglian Job arggg.I put it in gear it moved a little then just slipped and wouldn't move at all. Took of the clutch housing and there was friction material everywhere, the clutch had disintegrated so it was metal on metal. Not too hard to replace a clutch the worst bit is getting the damn flywheel off which is much easier with then engine in the car. Also if you go ahead and replace the clutch do the crank oil seal while you're in there. :D
Edited by jsiggee, 06 March 2014 - 02:27 PM.
#3 Gremlin
Gremlin
  • 2,142 posts
Posted 06 March 2014 - 02:54 PM
Was it wet, it might be water contamination
#4 Dusky
Dusky
  • 5,322 posts
Posted 06 March 2014 - 02:56 PM
Its a new clutch :P
Water is possible, mini slept outside tonight...
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 March 2014 - 04:10 PM
If its a new clutch are you sure the clutch shaft in the alloy clutch housing (wok) is returning and not siezed? thus holding the clutch lifted
#6 Dusky
Dusky
  • 5,322 posts
Posted 06 March 2014 - 04:17 PM
Yep, everything seems to be fine over there..
Thinking more of a geabox problem.. he makes a weard 'klunking' sound when he is in neutral.. but can't think what th eproblem there could be as the engine was working yesterday ..
#7 Dusky
Dusky
  • 5,322 posts
Posted 06 March 2014 - 07:11 PM
Bumpy
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 March 2014 - 09:54 PM
Well if the shaft is not seized and lifting the clutch, then its time to investigate with the clutch cover removed
#9 Dusky
Dusky
  • 5,322 posts
Posted 06 March 2014 - 11:19 PM
Will do.. But i think something around the gear selectioner broke inside( if that is possible)
#10 Cooperman
  • 23,513 posts
Posted 06 March 2014 - 11:28 PM
You might have ripped the centre out of the clutch plate. Take a look at the 'Tour of Cheshire' thread on 'Minis in Motorsport' as Dave & Jennie (Rally1380) had that happen last weekend and there are photos of the clutch plate in pieces.
#11 Dusky
Dusky
  • 5,322 posts
Posted 07 March 2014 - 07:47 AM
Will have a look this week, I hope its something 'simple' like that :o Not fond of splitting box and blok:/
#12 Dusky
Dusky
  • 5,322 posts
Posted 09 March 2014 - 11:26 AM
Found the problem, it nearly killed me i think..
#13 Dusky
Dusky
  • 5,322 posts
Posted 09 March 2014 - 11:27 AM
What are the torque settings for these bolts? Can I reuse them? With loctite probably?
