Specialist Components Mpi Upgrade Results
22 replies to this topic
#1 davidgrantsail
davidgrantsail
    Just On Tickover
  • 8 posts
Posted 06 March 2014 - 07:39 PM
I have a JCG 90bhp converted car (i know its not likely to be anywhere near that output) I know there are people on here with the Specialist Components MPi setup, I was wondering what spec people had and what gains they had form normal to SC gear.
#2 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 06 March 2014 - 09:47 PM
your benefits will come from being about to run performance mods that you can then supply the correct air and fuel too, which you can't do with the MPI ECU.
#3 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 07 March 2014 - 12:04 AM
I to would love to see some power figures given by these kits on tuned mpis
#4 Mpi Mark
Mpi Mark
  • 126 posts
Posted 09 March 2014 - 06:29 PM
I second that sir jake... Would be interested in mpi results and tuning this route vs supercharging...what's best per £ !
#5 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 28 September 2014 - 09:11 PM
A delayed reply to this but I have now fitted the SC kit and before I did I had the car rolling roaded. 72 bhp and 87lb/ft, afterwards I have achieved 91bhp with similar peak torque but holding alot more alot later in the revs. Fueling before ran lean after 5k but now I have my redline set to 6800.
Well worth the money spent to actually get the bhp from the engine mods.
#6 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 28 September 2014 - 09:12 PM
Just quoted this as a way to tag you.
#7 Mpi Mark
Mpi Mark
  • 126 posts
Posted 28 September 2014 - 10:15 PM
Good man sir jake!! What mods do have on your set up besides the sc set up ? Cheers Mark
#8 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 29 September 2014 - 05:50 AM
Jcw garages 90kit, vernier duplex, sw5 cam, competition valves, arp headstuds,
Quaife atb Diff, sc/cr box with drop gears, 10 row oil cooler. Probably a few other little things to.
Planning a rebuild with an sw10, balanced crank rods and flywheel and going 1330.
#9 Mpi Mark
Mpi Mark
  • 126 posts
Posted 29 September 2014 - 09:10 PM
This is my problem. I'm thinking that if an all singing all dancing vmax 150 conversion on the mpi comes in at approx £4000 and includes the emerald ecu is it not better bang for the bucks than adding all the above as my car has no where near the upgrades your has. Basically my mpi has Lcb , k and n, full rc40 stainless fuel pressure boost and a skimmed head.. Your car sounds quite something sir jake!!
#10 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 30 September 2014 - 06:09 AM
The vmax 150 kit requires your car to have a '90bhp' kit fitted.
My worry is that it would've been to much for giving the car abuse on track.
Cheers it's good fun to drive, could do with being faster but hey Ho it's only an 8 valve.
#11 Mpi Mark
Mpi Mark
  • 126 posts
Posted 30 September 2014 - 06:12 AM
Sounds quite a spec ....cheers for the info sir jake !
#12 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 30 September 2014 - 09:34 AM
Are you talking about the Plus Pack? i did think you HAD to have that, as its an extra £1700.
#13 sirjakethebrit
sirjakethebrit
  • 87 posts
Posted 30 September 2014 - 04:50 PM
Probably is been a while since I looked to be honest. I think the supercharger kit with a standard 1275 gives circa 100? But again I could be miles out as it's ages since I dreamed of that kit.
Would love a go in one, fitted at 150+bhp, round a track especially somewhere I know like Cadwell.
#14 Mpi Mark
Mpi Mark
  • 126 posts
Posted 30 September 2014 - 08:21 PM
Lcb, modified head and the like comes on the 150 plus kit.. By the look of it all set up all singing and dancing 150 vmax kit is £4500 ish.....oooo sooo tempted!!! Cheers for your input sir jake!!!
#15 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 30 September 2014 - 08:37 PM
very tempting
I would definitely budget a gearbox in to that as well though, mpi's being renowned for their gearboxes, x pin would be a must I would have thought
