Radiator - 2 Core?4 Core?alloy?
14 replies to this topic
#1 Mini Steve
Mini Steve
  • 512 posts
Posted 06 March 2014 - 11:01 PM
Want to put a new radiator in my mini an trying to get some opinions.
Have a 1340 an will be running a 45 weber.
Looking at minisport an minispares at all the options but don't know what to go for!
Any advice be brilliant!
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,095 posts
  • Name: Neil
Posted 06 March 2014 - 11:07 PM
I have just bought and fitted a performance two core rad for my clubby. It's only a 998 at the mo but will be going over to a warmed over 1293 next year. My mate Paul has 108 bhp motor in his Cooper replica and it's running the same rad with no issues.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 March 2014 - 12:56 AM
Same as above I have the MiniSpares 2 core rad in my 1330 without issues
#4 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 07 March 2014 - 03:43 AM
It's probably a bit hotter in the summer where I am so my car runs pretty hot in traffic with the 2 core so I put in one of these
http://www.minispare...44.aspx|Back to
My car also has the auxiliary fan in the wing which helps. With the 2 core the fan ran pretty much all of the time.
#5 Midas Mk1
Midas Mk1
  • 5,796 posts
  • Local Club: S.U.N.M.C
Posted 07 March 2014 - 06:23 AM
I didn't find the ms two core that good to be honest...
#6 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 07 March 2014 - 11:18 AM
what was your engine spec midas?
freaker
#7 sonikk4
sonikk4
  • 16,095 posts
  • Name: Neil
Posted 07 March 2014 - 11:27 AM
I think more info on the engine thats going to be cooled or engine spec that folk have had issues with certain rads would give everyone a better perspective.
#8 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 07 March 2014 - 11:59 AM
 The OP had his spec listed, my car has a 1293 A+ 276 cam 1 3/4 SU LCB RC40 DTM 2 box. The 2 core definitely had issues keeping it cool when it was 80+F
#9 sonikk4
sonikk4
  • 16,095 posts
  • Name: Neil
Posted 07 March 2014 - 12:10 PM
Your spec is more detailed and its the details that count. And like you said your summers may be hotter than here in the uk. There could be other issues as well that may lead to a rad not working to full efficiency ie worn water pump, stat not working correctly and so on.
I just went down this route to see what my problems were and actually found the rad had issues so went for the twin core performance one. Personal choice for me and on a recommendation.
I think if i was going to go for a higher spec engine then maybe a four core would be better or aux cooling or both.
#10 Midas Mk1
Midas Mk1
  • 5,796 posts
Posted 07 March 2014 - 12:33 PM
freaker
Mine struggled with a 1275 266'd stage one in traffic, with new waterpump / thermostat etc. On l2b it was a case of heater on full - hardly super cool as described...
Then fitted a thermex, same engine components, and l2b the year later (which was hotter!) - it never went past 2/3's.
Now with a 105 horse engine its starting to struggle, so as part of my winter mods a mocal oil cooler has been fitted. Both engines setup by a pro on the dyno, ie not running lean / incorrect timing.
Aux fan with it was a must, i saw hardly a difference over the standard 25yr old 3 core.
Edited by Midas Mk1, 07 March 2014 - 12:35 PM.
#11 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 07 March 2014 - 02:22 PM
I fitted a 4 core ali rad to my supercharged and its noticeably cooler, used to sit at 190 deg, now its 160 on the move. In traffic I have to use aux kenlowe fan. I have my heater plumbed in with no tap so its always "on".
#12 jaydee
jaydee
  • 8,565 posts
Posted 07 March 2014 - 03:44 PM
to be honest i'm sceptic about these 2 or 4 core 'special' rads, the 3 row rad is proven to be as good and cheap, you can use an aux fan if needed.
A good alternative is fitting one of those big alloy rads, they holds more water and are good enough for use with no aux fan fitted.
#13 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 07 March 2014 - 03:49 PM
The ali one I have is about twice as thick as the standard rad - Stuart from Vmax had a few last year.
#14 Mini Steve
Mini Steve
  • 512 posts
Posted 11 March 2014 - 03:50 PM
Few mixed opinions then!
I'm thinking the two core with a electric fan as well is best option.
Like this one... http://www.minispare...px|Back to shop
#15 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 11 March 2014 - 04:26 PM
I have an alloy one and the temp never moves above the middle of the gauge. It doesn't matter if I sit in traffic in the middle of summer. My old 1275 used to struggle a bit with a standard rad in summer in traffic but that may be because the rad was old.
