Im So High! I Want To Get Loooow!
21 replies to this topic
#1 DazWood
DazWood
  • 182 posts
  • Local Club: North East Mini Club
Posted 07 March 2014 - 12:05 PM
Ive searched this and come up with nothing
Basically Im running hi-los on the rear, wound all the way in, & Im still looking like a monster truck!
Am I missing something? Is there something I can do to lower it down more?
Im thinking of getting hi-los for the front too. But dont want to waste the money if im not going to get much lower
Any advice would be much appreciated
#2 998kid
998kid
  • 473 posts
  • Local Club: Essex Mini Club
Posted 07 March 2014 - 12:07 PM
Have you replaced the donuts recently?
#3 JamesGodfrey1992
JamesGodfrey1992
  • 422 posts
Posted 07 March 2014 - 12:09 PM
Do you not need to fit lowered shocks too?
#4 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 07 March 2014 - 12:10 PM
If you have recently replaced the cones, which it appears you have, otherwise you have a serious problem, you need to let them bed in. Just drive it and they'll eventually settle.
#5 Carlos W
Carlos W
  • 10,115 posts
Posted 07 March 2014 - 12:12 PM
Also, ensure the Hilo is sitting properly in the cone
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 07 March 2014 - 12:17 PM
Are the trumpets sitting correctly in their respective cups?? are the cones new? also you may find you have to remove a small section of the hi lo to enable the car to sit lower.
This is from the Minispares page
If you need the car even lower,dispence with the locking nut which was never on the originals and shorten the main adjuster bolt 3/4" and circlip.
#7 DazWood
DazWood
  • 182 posts
Posted 07 March 2014 - 12:23 PM
Yeah the doughnuts have not long been fitted. Everything seems to be seated fine.
As for the shocks im running KYB gas-a-justs front & back, so I would imagine these would be perfect for lowering.
Im guessing im just impatient and im not giving time for the cones to bed. Its not a runner as of yet, so im guessing its going to be a while before they bed correctly.
I just thought the weight of the car would of pushed them down enough.
Cheers people
#8 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 07 March 2014 - 12:26 PM
Fronts, are your shock mounts on the correct sides?  Rears, are they seated correctly?
#9 DazWood
DazWood
  • 182 posts
Also I replaced the nuts on the hi-los, which may have been thicker, adding to my problem.
Ill try removing the locking nut & replacing the remaining with a thinner nut.
Thanks again
#10 DazWood
DazWood
  • 182 posts
Posted 07 March 2014 - 12:27 PM
Im pretty sure they are & yes everything is seated correctly
#11 stickycreambun
stickycreambun
  • 1,865 posts
Posted 07 March 2014 - 02:15 PM
Dang I thought mine was high when I fit new cones!
#12 miniyellowmini
miniyellowmini
  • 595 posts
Posted 07 March 2014 - 02:25 PM
I fitted new cones with the Hilos set to the lowest setting about 3 weeks ago and I've already noticed they have settled a bit. Although they weren't quite as high as yours after fitting. They will settle eventually I'm sure.
Could also check you have the correct knuckle fitted. The one without the spacer is the one you want, although I doubt the spacer would raise it much maybe extra 5-10mm
Edited by miniyellowmini, 07 March 2014 - 02:28 PM.
#13 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 07 March 2014 - 02:30 PM
My clubby is set as low as it goes and still sits about normal ride height (new everything). I don't use my car all year round so it will take a little while longer for it to settle
#14 jaydee
jaydee
  • 8,565 posts
Posted 07 March 2014 - 02:33 PM
KYB silver dampers are notorious for affecting ride height.
You need to wind down hi/los if have them, cones will settle, but take a longer time than with other dampers, of the OEM and adjustable variety
#15 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 07 March 2014 - 02:35 PM
For the front I'm going with the car has no engine!
