Fitting Ap 4 Pot Calipers
21 replies to this topic
#1 westlin
westlin
  • 281 posts
Posted 08 March 2014 - 03:09 PM
Bit of a head scratcher this afternoon. I bought a set of Metro Turbo 4 Pot calipers to go on my sons project, but when I attemp to fit them I hit 2 issues. 1) to centralise the gap between the caliper and the disc there is a gap between the upright and the mounting flange on the caliper. 2) the metro flange hits the caliper.
I'm fitting 8.4 vented discs with the package.
Do I have something missing, should I not be using the metro flange?
Help!!!
Thanks in advance
Stephen
Edited by westlin, 08 March 2014 - 03:09 PM.
#2 tiger99
tiger99
  • 8,584 posts
Posted 08 March 2014 - 07:23 PM
I believe you should be using the standard Mini disc brake flange.
#3 Carlos W
Carlos W
  • 10,115 posts
Posted 08 March 2014 - 07:30 PM
I thought it didn't give you enough clearance?
#4 Carlos W
Carlos W
  • 10,115 posts
Posted 08 March 2014 - 07:34 PM
http://www.minispare...9A.aspx|Back to
#5 petey81
petey81
  • 1,352 posts
Posted 08 March 2014 - 07:40 PM
Get some pics up, search on this forum as I think another member had the same issue.
#6 westlin
westlin
  • 281 posts
Posted 09 March 2014 - 12:56 PM
Here are the pictures
#7 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 09 March 2014 - 01:27 PM
I thought you had to use Metro hubs! Part number NAM6450F
#8 Sheikh Pip
Sheikh Pip
  • 239 posts
Posted 09 March 2014 - 01:31 PM
You do, I've just dug mine out of the cupboard, Defo part number Nam6450F.  I really must fit mine one day... Lol
#9 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 09 March 2014 - 01:59 PM
metro AP 4 pot calipers, metro drive flanges/ vented discs, era turbo caliper bolts and Goodridge braided hose kit.
#10 westlin
westlin
  • 281 posts
Posted 09 March 2014 - 05:11 PM
There supposed to be metro drive flanges, the had the raised guides on the front before I machines them off. If they are not can some one tell me the diameter they should be
#11 westlin
westlin
  • 281 posts
Posted 09 March 2014 - 08:27 PM
Been surfing away all afternoon, looks like the flanges I have are early ones and thus bigger. Can someone who has the later ones supply me dimensions, both across the face and the back boss that fits the hub.
thanks
Stephen
#12 westlin
westlin
  • 281 posts
Posted 10 March 2014 - 12:20 PM
Ok I think im getting somewhere. Ive now taken the flange of the disc and measured it. Clearly the diameter is to large but the back element that has the spline in is only 30mm long. Talking with minispares the hub they sell (nam6450f) is aprox 49mm. Again surfing on the net I think these are for non vented. Does any one have a set if vented flanges kicking around that would like to come to a new home .
ive added some pictures to show what im talking about.
If someone could confirm im not going mad
Stephen
#13 ibrooks
ibrooks
  • 1,017 posts
Posted 10 March 2014 - 01:21 PM
It might just be me but the disc doesn't look to be seated properly on the drive flange which makes me question what the discs are for. Are they definitely for a Metro setup or are they for one of the proprietary setups that are available and therefore maybe meant to be used with a different drive flange. They clearly aren't standard Metro so it does make me wonder.
I'm not in a position to go and measure a flange but I do have this kicking around from before I built it all up.
Looks like 1 3/8" to me so where Minispares' 49mm comes from is a bit of a mystery. The old Mini flange is 1"
And this is the best I can do on a comparison of diameters.
Iain
#14 westlin
westlin
  • 281 posts
Posted 10 March 2014 - 02:03 PM
Discs came from mini spares. I did look at these pictures, but I also found others that showed 2 different backs, the one showing vented was bigger. When I find the link Ill send it over
#15 Scott@minispeed
Scott@minispeed
  • 200 posts
Posted 10 March 2014 - 02:08 PM
Stephen
Your drive flanges are the vented type
