Fitting Ap 4 Pot Calipers
#16
Posted 10 March 2014 - 02:18 PM
would you agree?
#17
Posted 10 March 2014 - 02:23 PM
Yes our new vented flanges are the same outside diameter as our new standard flanges
#18
Posted 19 March 2014 - 09:18 PM
hi guys been reading thought this and im a bit confused as im having the same sort of issues, im wanting to fit AP metro 4 pot calipers, iv fitted all the brake lines ready just struggling now fitting the disc and calipers.
i got the disc, bolts and everything i fort i needed bar the drive flang's from minisport, so instead i drilled mine to allow the bigger bolts to go thought to the disc. i came to fit them today and found that the disc hits the swivel hub, as i missing a spacer of some sort or do i have the wrong drive flange for my vented disc ?
i also found if i bolt the disc up and slide the caliper over the disc with pads in i carnt bolt the caliper to the hub either ? like im missing yet anther spacer inbertween the caliper and hub am i right or wrong there to ? but when i just slid the flang/disc onto the drive shaft free floating so to say and bolted the caliper up tight, the disc then cleared the hub but then i only have a couple of threads showing on my drive shaft ? so i want be able to tighten the flang up. have i got this all wrong or am i missing parts help would be great as im ment to be out init this weekend
thanks ben
#19
Posted 19 March 2014 - 10:57 PM
#20
Posted 20 March 2014 - 07:12 AM
#21
Posted 20 March 2014 - 03:30 PM
Engine in or out won't make a blind bit of difference. So long as the bearings are properly seated in the hub then when you do the hub-nut up it will seat the drive-flange and therefore the disc and it won't move in or out.
Are you absolutely certain your calipers are Metro 4-pots? just like the Mini's twin-pots AP scaled the design and they were fitted to all sorts of things so there are calipers out there that look exactly the same but are not quite the same size.
I'm also puzzled by your drive flanges - the measurements you provided don't seem to stack up with the picture I posted (albeit with a highly inaccurate measurement - but not so far as the difference between it and your quoted measurement.
I've never had this sort of messing around sticking Metro 4-pots on a Mini (I didn't even have this much trouble putting MGF rear calipers on Mini hubs).
Iain
#22
Posted 20 March 2014 - 06:38 PM
yeah 100% sure as i got them of my mate old scrap metro turbo it self like they have been stored for again but not i fort i would fit them i carnt seem to get them to fit what sort of drive flang will i need then metro ones or do i need to ring minisport / mini spares and speak to somone and see whitch ones they tell me to buy lol ?
thanks ben
