Timing. What Works Best?
engine
8 replies to this topic
#1 overbored
overbored
  • 70 posts
Posted 11 March 2014 - 10:57 AM
Hi All. It's time for me to decide how to drive the camshaft on my Mini. It's a full group-A  MPI Cooper. The target is to get the best performance possible(together with the ultimate reliability). What should I consider?
A: GEAR DRIVE;
B. VERNIER DUPLEX(either all alloy or steel/alloy);
C: BELT KIT.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 March 2014 - 11:11 AM
Reliability v Cost v Performance is a Standard Duplex with tensioner in my opinion, and tensioners are used by some of the best engine builders on the duplex including AC here on TMF
#3 overbored
overbored
  • 70 posts
Posted 11 March 2014 - 02:28 PM
Thank you. Which kit is the best?
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 March 2014 - 05:06 PM
Have a look here on Minispares http://www.minispare...|Back to search
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 11 March 2014 - 06:10 PM
well if you can afford get the belt drive kit  http://www.minispare...px|Back to shop
as changing belt is a dry process .....No oil...... :highfive:
#6 Scoop77
Scoop77
  • 508 posts
Posted 23 April 2014 - 05:59 AM
So, from this, if you were changing to an adjustable duplex system you wouldn't need the tensioner?
#7 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 23 April 2014 - 06:42 AM
Well a chain only needs replacing once in a blue moon, whereas a belt needs replacing more often. So you're kind of creating a solution to a problem that never existed..
If it was me, I'd just stick with the duplex. More simple, and it is proven to be reliable. No one really knows for sure whether to fit a tensioner in this situation. You just have to look at the facts, and make your own decision. Some people do, and some people don't.
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 23 April 2014 - 11:42 AM
Standard duplex timing gear/chain, no tensioner, and offset keys (as needed) to set the valve timing.
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 April 2014 - 05:07 PM
Tensioner will be ok on a duplex and you wont be getting chain rattle when it stretches which duplex still do.
