Flywheel lapping is it the black center part of this flywheel set up I have that needs to be lapped in
Posted 14 March 2014 - 12:06 AM
Posted 14 March 2014 - 12:18 AM
basically you smear lapping paste on the crank tail then fit the fly assembly and move it back and forth and rotate it until you get a nice finish on the crank, the problem is that you cant rotate the assembly if you fully fit it over the crank..
Posted 14 March 2014 - 06:08 AM
Posted 14 March 2014 - 07:52 PM
You only need to lap the item which engages the taper on the crankshaft, not the complete assembly.
Posted 14 March 2014 - 08:35 PM
Posted 14 March 2014 - 08:38 PM
Good, have fun! Not a job that can be rushed....
I just realised that there is another good reason for not having the primary gear fitted, not just because it inhibits free rotation. Would you want lapping compound anywhere near the Deva bushes, or their running surface on the crankshaft?
Posted 14 March 2014 - 09:05 PM
