Are Oil Filter Housings Interchangeable?
4 replies to this topic
#1 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 14 March 2014 - 07:10 PM
Two questions really-
Are 998 and 1275 filter housings the same?
Are early and late ones interchangeable? (apart from the oil pipe size which I know is different)
#2 GraemeC
GraemeC
  • 7,467 posts
Posted 14 March 2014 - 07:28 PM
Sizes (flow) are the same between engine sizes.
However the gasket faces on the block/housing are much bigger on the A to the A+.
Edited by GraemeC, 14 March 2014 - 07:28 PM.
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 14 March 2014 - 08:01 PM
However the gasket faces on the block/housing are much bigger on the A to the A+. http://www.minispare...|Back to searchhttp://www.minispare...|Back to search
Thanks Graeme, the casting on a 1275 ex metro one I have is much more meaty than the one on my 998, do you know if they are interchangeable?
#4 GraemeC
GraemeC
  • 7,467 posts
Posted 14 March 2014 - 09:05 PM
Is the metro one much longer with (about) 3" through bolts?
They are interchangeable (if they're both the same gasket face) but the longer one can give clearance problems depending on your car/build. If you've got room though they do make screwing the filter on/off a bit easier.
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 14 March 2014 - 09:08 PM
that's the one, I want to use a standard shorter type so by the sounds of it I will be ok. Thanks for the help.
