Pushrod Wear
4 replies to this topic
#1 NZMini1275
NZMini1275
  • 227 posts
Posted 14 March 2014 - 08:25 PM
Hi am starting to reassemble my 1312 engine and need to know if i should replace these pushrods. I have 2 sets that are the same on the end. I read a post on here that said if they had the pips on the end they are worn and need replacing. Is this correct or can the small pips be dressed off.
I am fitting a new cam and followers.
Thanks Dan
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 14 March 2014 - 08:26 PM
I dress them off with a bench grinder. just the pip though, no more.
AC
#3 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 14 March 2014 - 08:29 PM
I read in Mini Magazine that they can be dressed off.
I didn't use anything too abrasive like a grinding disc so I did mine with a sanding disc on a mini grinder and they look fine.
Ian
#4 59 Speed
59 Speed
  • 674 posts
Posted 14 March 2014 - 08:30 PM
I can't believe it took me 4 minutes to type that.
AC you're too quick!
#5 NZMini1275
NZMini1275
  • 227 posts
Posted 14 March 2014 - 08:37 PM
Thanks for the very speedy answers, much appreciated. Ill add this job to todays list.
