Brake Servo Removal
6 replies to this topic
#1 dodger75
dodger75
    Just On Tickover
  • 6 posts
  • Local Club: brighton
Posted 15 March 2014 - 06:59 AM
hi hope i posted in the right part i am thinking of removing my brake servo its had later brakes and later sevo installed few years back by last owner all came from 94 mini i belive but i now want to remove brake servo and install vertical brake master cylinder my brakes are cooper s 7.5 just want to know what i need to get before i start cheers for any help .
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 March 2014 - 09:00 AM
New brake pedal and spring, ideally a new master cylinder baseplate, and some plumbing. Do you know if the rear cylinders were changed when it was fitted?
#3 dodger75
dodger75
    Just On Tickover
  • 6 posts
Posted 15 March 2014 - 01:24 PM
as far as i know everything was changed to modern (94) brake system so what items do i need to replace to remove moden servo cheers
#4 carbon
carbon
  • 2,590 posts
Posted 15 March 2014 - 05:18 PM
When you say vertical master cylinder do you mean the original tin can Cooper S type?
If you are fitting one of these then you will likely also need the pressure limiting valve for the rear brake circuit.
#5 dodger75
dodger75
    Just On Tickover
  • 6 posts
Posted 15 March 2014 - 05:28 PM
was probly gona fit the later one before they went to servo
#6 dodger75
dodger75
    Just On Tickover
  • 6 posts
Posted 15 March 2014 - 05:37 PM
not the tin one
#7 grumpy dad
grumpy dad
  • 305 posts
Posted 15 March 2014 - 06:12 PM
Hi
why would you want to go backwards in the braking department
do you want to leave a bigger gap
between you and the car in front ?
