Basically is wrapping the exhaust a good idea or bad. Im fed up of seeing the unsightly rust on the manifold.
Posted 16 March 2014 - 02:56 PM
Posted 16 March 2014 - 03:07 PM
It can increase the corrosion of mild steel manifolds due to holding moisture. If you're not to bothered about your manifold having a decreased lifespan then there's no other issues really.
Phil.
Hi
if you wrap the
pipes from the motor down LCB
and you cane the motor
all the welds will crack
Posted 16 March 2014 - 03:10 PM
well for a bit more info i have a stage 1 kit but its no fire breather. it is just a weekend run around. yes it is a mild steel lcb i was looking to wrap. i suppose i could just bung a ss lcb on it as my other option.
Posted 16 March 2014 - 03:50 PM
Hi
if you wrap the
Not necessarily..
Posted 16 March 2014 - 04:22 PM
I see it as a temporary "get you home" type fix, not to keep it on there.
Posted 16 March 2014 - 04:24 PM
I think he is talking about the Kevlar heat resistant manifold wrap rather than the 'holts exhaust repair bandage' type wrap.I see it as a temporary "get you home" type fix, not to keep it on there.
Posted 16 March 2014 - 04:31 PM
Ahhhh of course, sorry!
Posted 16 March 2014 - 04:45 PM
Posted 16 March 2014 - 06:49 PM
I warped a maniflow LCB manifold by wrapping it
Posted 16 March 2014 - 07:09 PM
Could be worth having it Ceramic Coated if its within your budget.
Always worth getting a quote
Posted 16 March 2014 - 07:33 PM
I would get it coated with a proper coating like a ceramic, Wrapping manifolds is good for motorsport or high performance applications where the engine is regularly looked at and checked over but not so much for a near standard road car.
It is good at keeping under bonnet temperatures down, however it doesn't get rid of that heat, it just means the heat is transferred down the exhaust further, as a result it can cause the rest of the exhaust to be damaged (cracking welds etc). As also stated it can hold water which isnt good for the manifold beneath, on a car thats used a lot it isnt much of an issue as it will evaporate off when the engines run, but if its not used much then the water can linger and rust out the manifold.
The manifold will also produce a fair amount of smoke when new and when its wet which isnt good for peace of mind (can look like something is on fire)
Posted 16 March 2014 - 07:37 PM
I have had one done for a project at work. Superb quality but VERY expensive.Could be worth having it Ceramic Coated if its within your budget.
http://www.zircotec.com/
Posted 16 March 2014 - 07:40 PM
Ball park figure Clive?
