Clutch Pedal Stuck Down.
Posted 16 March 2014 - 05:30 PM
Removed the clutch cylinder and the clutch is still engaged. Any ideas? I guess it's just stuck on the splines.
Think I have found the name of my mini PITA (pain in the ass).
Posted 16 March 2014 - 05:42 PM
i would think the simplest thing is that the clutch arm is sticking, just spray it in wd40 and leave it for half an hour, i bet that will free it off. the steel arm is prone to getting stuck in the end of the casing when it gets full of muck and corrosion
Posted 16 March 2014 - 07:12 PM
Posted 20 March 2014 - 11:42 PM
Posted 21 March 2014 - 01:11 PM
I strongly recommend that you also change the slave cylinder (maybe you have already), because if it was stuck, the bore is scored and/or corroded, and it will fail very soon. I also recommend changing the fluid more frequently, every 2 years for clutch and brakes, even if the car is laid up, as it saves a lot of aggro and expense later. You may want to try some brake grease (the red stuff, compatible with brake fluid, and rubber) or some silicone spray grease on the outer part of the new slave piston to discourage corrosion from external moisture. (The rubber boot never makes a perfect seal, and every time the piston moves, or the temperature changes, moist air is expelled or drawn in.)
Posted 24 March 2014 - 09:35 PM
Thanks for the advice guys.
