2Nd Gear Grinding
11 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 17 March 2014 - 11:42 AM
Hi all
After a rebuild on my gearbox with included new
Baulk rings, when changing down gears it grinds into
2nd but is fine going up gears.
So could it be the gear hub itself?
Tks
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 17 March 2014 - 01:00 PM
Take it back to the supplier. This could be a number of issues. If you rebuilt it yourself, you need strip and examine the components. Get an experienced person to help identify the issue.
AC
#3 087dave
087dave
  • 952 posts
Posted 17 March 2014 - 03:30 PM
Thanks AC
bit hard to find is a mini gearbox specialist in Ireland...
I have stripped the gear box today  and I cant find any worn teeth, there was a bit of swarf not that much
does anyone know what thinkness the baulk rings are to be as I brought the rings from ebay could already be faulty
is there anything else to look for on the 2nd gear hub?
Tks
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 17 March 2014 - 06:18 PM
Ok, does the baulkring fit on the gear cone with a gap, or does it bottom out ont he gear and spin?
Did you change the synchro hub springs for new ones?
AC
#5 087dave
087dave
  • 952 posts
Posted 17 March 2014 - 08:21 PM
Hi
It doesn't bottom out
There is a gap of about a 1mm between the cone
And ring
I also put new spring in the hubs
Edited by 087dave, 17 March 2014 - 08:22 PM.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 17 March 2014 - 09:35 PM
Ok does the ring grip the gear? does the inside of the ring look torn and damaged?
Does swapping then improve the grip?
Have you fitted all 3 springs? Does the hub feel tight or loose comparing to the 3rd/4th hub?
Ac
Edited by ACDodd, 17 March 2014 - 09:37 PM.
#7 087dave
087dave
  • 952 posts
Posted 17 March 2014 - 09:38 PM
Ya AC it does grip the cone and the inside is nt
Worn
Is there any checks I could do on the hub itself
To be honest it feels the same as 3rd and 4rd
Ya I fitted new springs.
Edited by 087dave, 17 March 2014 - 09:51 PM.
#8 087dave
087dave
  • 952 posts
Posted 18 March 2014 - 05:31 PM
Bump
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 18 March 2014 - 05:59 PM
From what you are describing there are no problems. I would need to see/feel the components to be able to advise further.
AC
#10 hotwheels
hotwheels
  • 198 posts
Posted 05 December 2015 - 03:34 AM
I have the same issue with my gear box, I recently replaced the bulk rings and it still grinds downshifting in 2ncd ugh
#11 Cooperman
  • 23,356 posts
Posted 05 December 2015 - 10:37 AM
Just double de-clutch on the downshifts - problem solved ;D .
#12 ace01
ace01
  • 458 posts
Posted 05 December 2015 - 10:54 AM
It is possible to put the inner part of the syncro hub in back to front.  The difference is easily missed.  This will lead to the symptoms you have.  Ask me how I know. :shy:  On mine it would only go into second on the down change with an almighty crunch and at very slow speed.  Stationary it was fine.
