I have twin hs2's in my 1275gt although it has a 1300 metro engine in it now.
Can anyone tell me if H6 needles are sufficient for this engine as it is running pretty rich and the mixture is not easy to get right at all. Ive used colortune and the lifting pin method but no joy.
I have just removed the carbs, cleaned them up and about to refit from scratch but thought I'd look into changing the needles before I bother going through the whole setup again.
From the description below it appears that the H6 needle is not correct or am I missing something? Please help.
Mini Cooper S Mk III, 1275 cc, (12H) 1969 on
Carburettor type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Twin SU HS2
Piston spring . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Red
Jet size . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.3 mm
Needle:
Standard . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . M
Rich . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . AH2
Weak . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . EB
Idle speed . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 600 rpm
Fast idle speed . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000 rpm
Cheers, Ross
