What Are Quickracks Steering Racks 2.2?
8 replies to this topic
#1 Jacks
Jacks
  • 102 posts
Posted 18 March 2014 - 07:11 PM
http://www.minisport...-2-2-turns.html what is it used for and what are the advantages and are they for track cars or road cars does it make the steering lighter or easyer to turn?
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 18 March 2014 - 07:27 PM
It is a faster rack, it means you only turn the steering wheel 2.2 turns lock to lock opposed to 2.7 turns with a standard rack (I believe) (less turning amount required to turn the car the same amount)
You can use it on the road but I dont know why you would want to, the mini steering is pretty quick already, and a quick rack will make the steering heavier overall
#3 Cooperman
  • 23,366 posts
Posted 18 March 2014 - 07:36 PM
+1. Really only for competition. It is unlikely to be any advantage on the public roads and will be heavier.
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 18 March 2014 - 07:47 PM
Combine this with a relatively small steering wheel and the steering will be very heavy
#5 Lsurt95
Lsurt95
  • 112 posts
  • Local Club: North East Mini Club
I changed to a quick rack a few weeks ago and to be completely honest i didnt find the steering any heavier, however the steering felt more direct and more responsive without it being twitchy.
#6 Cooperman
  • 23,366 posts
Posted 19 March 2014 - 12:43 AM
If fitting a quick rack a 15" steering wheel will probably be a good idea.
#7 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 19 March 2014 - 07:10 AM
+1 Found my steering more responsive as well but not any heavier than standard steering
#8 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 19 March 2014 - 07:12 AM
It is heavier. You're just not noticing it! :P
I had one in my first Mini because I thought I was a rally driver. Turned out I wasn't, and that I didn't need a higher geared rack at all! It's so far down the list of modifications I'd carry out on a road car now, that I personally really don't think it's worth it.
#9 Cooperman
  • 23,366 posts
Posted 19 March 2014 - 12:02 PM
I never run a quick rack even on my rally Minis as I think a big bump or deep rut could put loads into the steering which would not be 'holdable' with a higher ratio steering rack. I run a 14" steering wheel with a standard rack and it always seems great, even on gravel roads with the car well sideways.
The Minis steering is already a legend and the one main thing which was so great when the car was introduced.
But then, if money is no object and there is a perceived advantage, then fit one, but use a 15" steering wheel to avoid 'over steering' (rather than 'oversteering).
