Which Spray Gun For Primer?
5 replies to this topic
#1 Notay
Notay
  • 153 posts
Posted 18 March 2014 - 09:42 PM
Hi I am after a (HVLP?) spray gun for priming my mini. I understand I need a wide nozzles around 2mm - please correct me if I am wrong. I have a 3HP, 14cfm, 90ltr air compressor with a 10 mm bore air line.
Can anyone recommend a decent, but not major expensive spray gun?
Also, do I need to use a water trap in the air line?
Many thanks.
Notay
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 18 March 2014 - 09:44 PM
You need a water trap
Sorry I can't be of any help on your other question
#3 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 18 March 2014 - 09:56 PM
the Star range of guns get good reviews for a lower price range gun. I bought a Star S106. ($106 australian). I'll buy a second one with a 1.4mm tip. Just the tip costs $85 so it's worth buying a whole second gun!
http://www.ebay.co.u...=item56589c0aad
These days you want gravity fed. Generally 1.6-1.8mm tip for primers, but read your product TDS. The TDS will tell you everything you need to know. Pressure at gun, nozzle size etc. Probably 1.4mm for top coats/base/clears. But again, read the TDS.
The most important thing you can do is read the product TDS.
And yes you will need a water trap. I run a large one at the compressor, problem is the air cools along the length of the line, causing condesation, which while the air was warm and dry at the first water trap, at the gun it will be cool and moist again, so run a second water/oil remover at the gun. You should also run a regulator at the gun so you can allow for pressure drop along the length of the line.
Oh, don't forget, read the TDS!
Edited by sixtyeight, 18 March 2014 - 10:00 PM.
#4 weedim
weedim
  • 29 posts
  • Local Club: NI minis
Posted 18 March 2014 - 09:59 PM
I think the sealey ones are reasonably good going by my nosing about!!  :teehee:
#5 Daz1968
Daz1968
  • 2,058 posts
Posted 18 March 2014 - 10:37 PM
I bought a kestral from sprayguns direct, works fine for the cost and pretty well built.
I use a filter regulator with water trap as well as drop legs in the line, have a coalescing filter as well when painting and to be sure have a small water trap mounted on the gun, it's a small one made by devilbiss.
Edited by Daz1968, 18 March 2014 - 10:38 PM.
#6 kezzkitkat
kezzkitkat
  • 714 posts
Posted 22 March 2014 - 07:12 PM
Between a 1.6 and 2.0 gun set up but to be honest a 2 is like a hose u will have to go pretty fast with the same overlap I always use. a 1.7 sata gun for high build different set up for wet on wet and surfacer sorry can't suggest a cheap gun as I use sata and delivbiss I would hsve a look on. EBay for a gti
