Tappet Clarence's On 1275 Cooper (12A) Engine
Best Answer Cooperman , 19 March 2014 - 07:33 PM
I tend to ignore anything the Haynes manual tells you, a lot of it is just terrible information.
I get all figures from the original BMC Workshop manual.
+1 on trusting the original BMC Workshop Manual.
The original 1275 Cooper 'S' had valve clearances of 0.012" cold and there is no logical reason to change this. You will hear all sorts of reasons given, but the clearances are to allow for valve train expansion as the engine heats up. The only reason for increasing this setting is if a different ratio rocker shaft is fitted, in which case multiply the BMC clearance (0.012") by the rocker ratio. e.g., if going to 1.5 ratio rockers, divide by 1.3 and multiple by 1.5, which gives 0.014"
Go to the full post
Posted 19 March 2014 - 05:39 PM
When researching I found that 12thou seems to be the recommended setting for most engines, so that is what I did them to (0.30mm). I Carnt hear anything untoward, but it is a little awkward at the mo as my exhaust is blowing.
Does anyone know if it was correct doing a 12a engine at 12thou?
Thanks in advance for any help or tips. Cheers.
Posted 19 March 2014 - 05:41 PM
12 thou when cold is the correct setting.
Posted 19 March 2014 - 07:23 PM
Posted 19 March 2014 - 07:26 PM
Posted 19 March 2014 - 07:32 PM
Not everybody has access to the BMC manual Harry so the Haynes manual does a good job for what it it. .015" is noted in the BMC manual for competition engines.
Posted 19 March 2014 - 07:33 PM Best Answer
Posted 19 March 2014 - 09:11 PM
Thanks again.
Posted 19 March 2014 - 09:16 PM
At the end of the day thats what the forums about. If you have doubts or questions then fire away.
Posted 19 March 2014 - 09:21 PM
Check your email. There is something there that will help in the future. ![]()
Posted 20 March 2014 - 08:48 PM
Got it. Thanks Neil!! ![]()
Posted 20 March 2014 - 08:53 PM
No probs. Its a very useful bit of kit.
