hos the best way to clean out a gearbox with the gears still in
I thought gunk spray and leave and hose off and let dry upside down
then air blast it and then oil can the gears ???
can remove the dif
Posted 21 March 2014 - 09:30 AM
can remove the dif
Posted 21 March 2014 - 10:07 AM
I started a thread about this a while ago, and the general consensus was that you shouldn't bother. However, with all the grit I can see at the bottom of the casing, I'm going to try something. But I'm not sure what yet.
Posted 21 March 2014 - 11:30 AM
Couple of liters of paraffin or kerosine / pump diesel and a stiff brush, then clean the outside of the case off with wonder wheels.
Then rinse everything out inside with clean paraffin or kerosine / pump diesel again.
Don't be tempted to use petrol ever - my Dad nearly killed himself after washing motorbike parts out in a basin of petrol that exploded when the fluorescent lamp flickered and ignited the vapors. It took six months for the just the skin to heal and I can still smell burning flesh nearly 40 years later.
Posted 21 March 2014 - 11:40 AM
Washed mine out with paraffin, worked wonders
Posted 21 March 2014 - 11:44 AM
take it to a machine shop they all have hot washers and wont charge much to wash it all out for you , and the cleaning solution usally has a rust inhibitor built in but always advisable to oil everything after
