Starting
5 replies to this topic
#1 danny1
danny1
    In the navy you can sail 7 peas
  • 1,321 posts
  • Local Club: bumpstart
Posted 21 March 2014 - 01:52 PM
Right now I'm trying to get my mini started today but I'm having a few issues
Right now I've followed the Hanes manual
And I've connected up the white and black wire to the negative side of the coil on the white wire to the positive side of the coil
And connected the other white and back wire to the dizzy and I'm getting no spark on the plugs
Now I have to white and purple wires but I have no idea what there for
It's a Lucas sports coil I'm using
#2 jaydee
jaydee
  • 8,565 posts
Posted 21 March 2014 - 01:55 PM
Is this the first engine start from a rebuild or storage?
#3 jaydee
jaydee
  • 8,565 posts
Posted 21 March 2014 - 01:58 PM
Lucas sports coil have to be wired with a 12v live with ignition switched on and the +ve dizzy, negative is the white and black (two connectors for the coil, one to the dizzy)
purple is oil pressure sender iirc..
#4 danny1
danny1
  • 1,321 posts
Posted 21 March 2014 - 02:09 PM
Right I'll wire in a live feed from the fuse box and see if that helps
And yeah it is a first start
So it's rather exciting
#5 danny1
danny1
  • 1,321 posts
Posted 21 March 2014 - 03:50 PM
Right I have a live feed hitting the coil of the loom which is the white wire so there's no need to supply the car with a 12v feed, there's a black and white wire attached from the negative side and the dizzy side, and I'm still getting no spark at the plugs at all, so It could be down to points
#6 danny1
danny1
  • 1,321 posts
Posted 21 March 2014 - 04:05 PM
Right I've just checked that I was getting power through the Leeds by putting one end of my voltmeter in the of the dizzy lead and earthed it on the shell and managed to earth it through my at the same time now I felt the power being there so when inspecting my plugs there not the best so I think it should be an easy issues of getting new plugs for it
Fingers crossed
