Anti Siphon Fuel Neck Filler Removal
5 replies to this topic
#1 Remylebleu
Remylebleu
  • 709 posts
  • Local Club: On my ones :)
Posted 22 March 2014 - 11:28 AM
hi, just wondering if there is a way of removing this? or is it welding into the fuel tank?
would I be better off buying an earlier fuel tank without one fitted?
also do all standard fuel tanks fit all mini?
thanks
#2 surfblue
surfblue
  • 1,827 posts
Posted 22 March 2014 - 11:37 AM
All saloon tanks will fit all saloons.
There is extra pipework, fuel return thingy (technical term  :lol: ) on injection tanks that wont be needed for carb minis. Guess they could be blocked off?
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 22 March 2014 - 11:45 AM
Just out of interest, why do you want to remove it?
#4 Remylebleu
Remylebleu
  • 709 posts
Posted 22 March 2014 - 11:54 AM
Just put of interest, why do you want to remove it?
I was expecting this question, basically my fuel gauge works for the 1st half of the tank (or appears to be accurate) then once it gets to just above half a tank, the needle kind of does what it wants and either reads accurate (as far as I can tell) or sits just above the red and doesn't go any lower, short term its just easier if I could see inside the tank, long term, ill change the dial and fuel reader in the tank but its just a short term fix so I can tell where im at because I was on the red for 4 days and went and filled up and only got £11 in till it was full
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 22 March 2014 - 11:56 AM
makes sense, you could also use an old aerial as a dipstick. Would save the hassle of swapping the tank.
#6 Remylebleu
Remylebleu
  • 709 posts
Posted 22 March 2014 - 12:09 PM
ye ive been using a length of side trim, which would suggest I current have a 1/3 of a tank, which based on what ive put in and the miles ive done would be accurate
