is it possible to fit a vacuum advance unit to the aldon distributer?
What Have I Done? Carb Adjustments….
#16
Posted 25 March 2014 - 10:22 PM
#17
Posted 25 March 2014 - 10:36 PM
Yes just remove the plate on the body, lift the baseplate attatch the unit and screw on, but if your engine is standard then it wont need a Aldon yellow. What spec is the motor if its been modified with a cam, head mods and more then its ok, otherwise of no advantage.
What spec is your engine Steve?
Edited by KernowCooper, 25 March 2014 - 10:37 PM.
#18
Posted 26 March 2014 - 07:26 AM
I dont know to be honest. All the seller said was -
998 Rebuilt to 1000cc high compression
HiF44 Carb
K&N filter
Head work
Maniflow Manifold
Maniflow Exhaust
Inlet manifold changed
Uprated ignition coil
Aldon Yellow Dizzy
Electronic Fuel pump
I asked about cams and he sort of said yea but didn't seem to know much on them
#19
Posted 26 March 2014 - 10:52 PM
Well if its not a well sorted engine with a uprated camshaft, and head mods then I'd say you'd be better off with a standard 998 distributor with vacuum advance. Also the HIF44 is a bit big for a 998, HIF 38 would be better
#20
Posted 27 March 2014 - 08:10 AM
Yea I have switched to a 38 now
If I fit a vacuum advance onto the Aldon will that be the best solution?
#21
Posted 27 March 2014 - 08:16 PM
I dont think your engine is tuned enough to need more than a standard distributor Steve.
#22
Posted 28 March 2014 - 02:37 PM
Grtz!
